Check to make sure that all the plug wires are snaped on tight. I had this problem and is was a loose plug wire. Not so loose it fell off the boot, but loose enough to give it a skip at low idle.
Pull the boot up the wire and put the little snap collar on the plug then push the boot down. That way you are sure it is seated right.
