Just wanted to say hello to everyone. I'm Steve and have been the owner of a 99 GMC Suburban 2500 454 2wd for that last 5 years. I joined the site to help in my quest to tackle fault codes. I've searched some posts on the p0452 & p0453 Evap codes and gained some info.
a. Seal fuel pump gasket ring with lube
b. Change pigtail harness on pump
c. ensure no moisture is inside connector
I have the 4 volume 99 FSM set. I changed the fuel pump out about a year ago along with the pigtail harness supplied. Code never showed up until about 6 months ago. Emissions is due. In the last week I've installed a new gas cap and cleaded codes, no change. Cant shake p0452, comes back on startup.
I could try:
dropping tank and checking for vacuum leaks on the evap hose.
check 5v on pressure switch
install another $200 pump assembly (that sucks)
Any other suggestions?
Thanks for looking, Steve
1986 GLHS #295
1991 Daytona ES 2.5 N/A (#1 sons ride)
1989 Daytona ES 2.5 TI (#2 sons ride)
1983 Dodge Rampage Prospector (out of paint 12-5-2010) converting to TII & Charger ground effects
1999 GMC Suburban 454 2wd
2005 Chrysler 300 Touring AWD
Triangle, VA
I could try:
1986 GLHS #295
Triangle, VA
