Hello,
We just bought a '98 K1500 Suburban with ~87K miles. Looks like a nice little forum here, wondering if you folks could answer a few questions.
1) What kind of engine is the 5.7L Vortec? OHV or OHC? SEFI or other? timing chain or belt? Would you classify it as mass air or speed density? anything else to know?
2) Since this is my first OBD-2 vehicle, the wife offered to get me a scanner for Father's day + birthday +.... Any suggestions on a good DIY scanner that will provide reasonable access to trouble codes (including GM specific codes, if possible) and PID's. Don't want to break the bank with this one either. Not too worried if it's backwards compatible with my Ford EEC-IV vehicles either. I can pull trouble codes on them with nothing more than a paper clip and I don't think either of them will output PID's to a scanner
3) I guess the transmission is a 4L60E, is that right? Is it a good transmission? What kind of gear ratios? Does it need any special attention other than periodic fluid changes/filter changes?
4) What about the transfer case? What shall I call it (I have 2H, 4auto, 4H, and 4L options)? What's the low range ratio on it? What's the basic operating principle behind the 4auto setting?
5) While discussing the 4x4, what's the mechanism for the front axle disconnect? Is it reasonably reliable? How would this be disabled to acheive a 2L setting (for backing up trailers and such)?
6) How do I determine what my differential gear ratio is? What are the chances I've got a limited slip differential and how would I find out?
I'm sure there will be other things come up, especially as problems surface. Thanks in advance for any information.
