I have a 90 Burban with a 350 FI engine. I need new piston rings. I was wondering what is the average cost to me if I have a mechanic do the job.
Super Moderator
I'd say between 1000 and 1500 at least. Going that deep into the motor is going to be considered an engine rebuild. How do you know you need rings anyways?
Well, I have to add a quart of oil about every 2 weeks. there are no leaks anywhere.
I am suspecting that the oil is being burned because of blowbye, due to worn rings.
New Goodwrench motor for ~$1600
If it is going to cost you $1000-$1500(and that seems about right considering shop labor is $100/hr or so), you might as well get a new-not rebuilt,new-GM Goodwrench motor for the same $1500-$1600. I'm planning to do the same thing with my 196,000 mile motored Suburban(which is running good).It is possible it is just valve guide seals-does it give a good puff of smoke at startup,and then not smoke after warmup?
If you have a lot of blowby it should run like crap(power down,and missing),and the plugs should be fouled?
Luck,
Charlie
have you done a compression test? or a leak down test? the leak down will show if the rings are bad and you can get a short block almost anywhere for $499+ depending on what add ins you add. i do a leak down and see if it is valve guides or rings....mike
