Alright finally got around to installing my 2 VVME HID kits. Connected everything up didn't use the optional harness as I just pulled the DRL fuse. Went to turn them on and got nothing?:grrrrrr: Double checked all the connections to makesure nothing was loose and all good to go. The only thing is my Hi beam indicator is on in my cluster??? With the ignition on the high beam switch will not switch the relay but with ignition off I can hear it switch the relay? So some help would be greatly appreciated here. Are the ballasts supposed to be secured to metal so they are grounded?
Thanks
Magna
---------- Post added at 08:15 PM ---------- Previous post was at 06:47 PM ----------
Figured it out. Switched the plugs into ballast and they work!
Thanks
Magna
