I have a 2002 Suburban with a 5.3L FLex Fuel engine (code Z). It won't start at all. Not even a lick. I checked the fuel pressure Schraeder valve and got a little gas when I depressed it. I then tried spraying a little starting fluid (ether) into the throttle body. The engine caught and ran for a few seconds.
I can hear the fuel pump run for a few seconds and then stop when I first turn on the ignition switch. There are no trouble codes set.
Any suggestions as to where to go next for troubleshooting?
Thanks.
Thanks.
