2004 TB with 58,000 noise from front end on small bumps/washboard road surface at low speed. Frank
F frogate · Registered Joined Sep 28, 2006 · 1 Posts Discussion Starter · #1 · Sep 28, 2006 Only show this user 2004 TB with 58,000 noise from front end on small bumps/washboard road surface at low speed. Frank
2 2003slt · Registered Joined Aug 8, 2006 · 7 Posts #2 · Oct 5, 2006 Only show this user Sounds like sway bar bushing, links, or both could be bad.
S snk02blazer · Registered Joined Aug 16, 2006 · 9 Posts #3 · Oct 7, 2006 Only show this user wasnt there a recall for the lower control arms on the tb? or did that not cover the 2004 model?
N nstro · Registered Joined Jan 1, 2007 · 2 Posts #4 · Jan 1, 2007 Only show this user I had the same problem, I solved it by tightening the two 10 mm bolts in the rod that goes across the top of the battery
