New to the forum with (maybe) an old problem.
After letting my 1996 Chevrolet 1500 work truck with 5.7L vortec v-8 and 4L60e trans (203K on the engine, recent rebuild on trans) sit in the driveway for a couple weeks, I hopped in to head to the parts store. And...
At very low load, rpm between 1000-1500, it accelerates normally for a couple seconds, then nearly dies for about 2-3 seconds, then "catches up with itself" and pulls hard. Did the same thing for nearly every upshift. When I tried, from a dead stop, to accelerate enough to get the truck moving then floored it, same thing. It "died" enough to throw me forward, then caught up and pulled hard to 5000+ rpm.
So, I headed out today to try to get some more info--and buy a can of MAF cleaner, just in case.
Here's what I found, and it puzzles me some.
There are no codes or Check Engine Light. The hesitation is initially there as before, but after I drove for about 15-20 min, it seemed to be gone. While I was driving, I was watching my scanner which was set to the monitor mode. Every thing looked pretty normal, except the timing. At idle, the timing was -15 or -16 degrees. When I accelerated, it went up(?) to -33 degrees. When the hesitation hit, it dropped to -20, -12, even as low as -4 degrees, only to instantly go back to -33 when the hesitation stopped. Remember that this hesitation lasts only about 1.5-2 seconds. Much later, when I got back home, the idle timing was -24 degrees, but the driving timing was still usually -33. There were some times that it was mid-20s. When I step on the gas, from a setting of -33, timing changes, very rapidly and of short duration, to around -19 degrees. Then it goes back "up". I checked the TPS and it usually showed 3-8% open. Load was 4-18%, depending on going uphill or downhill.
Now, it's been a while since I really played with things like timing and carburation (I told you it was a while ago), but I remember setting my chevy v-8 at about 10 degrees at idle and having about 32-34 degrees at max advance. I don't even remember getting an engine to run with negative timing.
The readings from all O2 sensors look correct. The front ones rapidly flucuate from about .12 to .87. The rear fluctuate from about .06 to .18. The TPS shows good throttle position throughout the range. One thing that I'm unsure about is the Long Term Fuel settings. The scan tool showed them at -11%. That seems a little high to me, but I don't really know what they should be. Inlet air temp looked correct at about 102. Air flow seemed reasonable for the load factor.
The fuel filter is about 5k miles old, so I'm not convinced it is at fault. I can't, thus far, find my fuel pressure gauge to check for low pressure. However, the way the truck pulls at full throttle, after it gets over its hesitation, makes me think the pump is working properly.
I thought the crankshaft position sensor might be a culprit, until I did a web search for how it works. Seems to be an either/or. Either it works, and the engine runs, or it doesn't, and the engine won't start. I couldn't find anything that talked about variable timing being generated by the CPS.
I'll clean the MAF, since I got the cleaner at the parts store, but don't expect that to be the problem.
I guess next up is the distributor. I've heard that the drive gear can wear badly and cause problems. However, a bad gear would seem to be a candidate for problems throughout the operating range, and not just at low rpm. Am I wrong on that? Wouldn't the distributor also cause misses throughout the operating range?
The fact that this hesitation/stumble seems to occur only at fairly low rpm--and now seems to go away after 15-20 minutes--really has me puzzled.
Any ideas????
Thanks,
JC
Any ideas????
Thanks,
JC
