Hey JJ, Welcome to the GM truck club.
Of the things that you listed, there are only 2 that I think could have caused the oil consumption,,, the valve stem seals, or the piston rings or both. I don't know why they would replace the other things, but it sure was nice to get that many new parts. As far as what's causing it now, I would suspect that the cylinder bores are not perfectly round & this will not allow the rings a perfect seal & the oil is getting past & mixing with the combustion charge & blowing out with the exhaust. It's also possible that some of the valve stem seals could have failed again, the oil is running down the stems, into the intake charge & again blowing out the exhaust. 2 qts in 3,000 miles is probably not going to be enough for you to see the blue smoke out the exhaust, but you could pull the spark plugs & see if there is any carbon residue on them because this would indicate too much oil getting into the cylinders.
How many miles since the repair was done? Were these repairs done at 50K when the oil burning started, or were the rings & valve stem seals just done recently? If the rings were only done recently, then they might not have had time to seat yet.
