1 - 6 of 6 Posts
1988 k1500
Hello i have a 1988 k1500 , recently i was at a red light when my oil gauge was on the first like on the gauge then dropped to 0 and made the check gauges light turn on , but then quickly it went back up to the first like again. Any help i would really appreciate it. Thanks
First thing that comes to mind is a new oil pressure sensor is needed.
Stupid question...Have to ask. Did you verify you have the appropriate amount of oil in your vehicle?
I was running down the interstate doing things with my mother's truck I shouldn't when the oil pressure fell out the bottom. After a panic-stricken drive to the first exit and parking in a deserted parking lot, I crawled around looking for a hole or something, thinking I had thrown a rod or blown something out the side. Turns out ALL the oil had leaked out of the truck after an oil change (loose filter) and it just needed a gallon of oil from the convenience store...
98 gmc k1500 5.7
wrong sensor , check make sure its the correct sensor for your truck , count the wires and the prongs in sensor, is it a gm sensor, some aftermarkets are bad in the box, i just posted about same issue on the Silverado / sierra forum
1 - 6 of 6 Posts
