1 - 3 of 3 Posts
Discussion Starter #1 (Edited)
Anyone know what can cause oil on spark plugs?
I believe a old valve cover gasket can be a problem but I’m not sure,
At first it was having a cylinder 1 misfire until I replaced the spark plug and discovered the old one was oily swapped it and It started running again,
1 1/2 months later it returned? Any thoughts? No smoke or oil consumption that I know of
Howdy and Welcome.!
Just a word of encouragement about posting on forums.
Punctuation helps a lot.
In addition, an extra line feed helps make posts a bit easier to follow and read.
The oil seals could be failing, or worse the rings could be gone. How’s your compression?
1 - 3 of 3 Posts
