Replaced, first with denso, code kept popping back up, replaced with ac-delco, from dealer, code pops up again. Any ideas as to why?
On 1996, chevy silverado k1500, with 5.0L(305cui) vortec. Has 4 sensors, bank1sensor1, bank1sensor2, bank1sensor3, bank2sensor1. Only bank1sensor2, and bank1sensor3, are not reading proper voltage fluctuations in live data mode on my code reader, haynes repair manual used to find out what the readings should be on a properly operating o2 sensor. Manual says if the voltage reading is steady, or only moves a little bit, the sensor is faulty. 4 sensors now, including the ac-delco, are all showing the same voltage readings. Not even proper voltage to start, then eventually not, right after installing them, they show improper voltage readings. Ugh. Hopefully this is clear enough, i am exhausted. Please, anybody, who can help, please do? Thank you.
