1 - 3 of 3 Posts
2000 blazer 4wd
Got this code over a month ago. Started off by replacing the O2 sensors since they looked old. No change. Replaced a lot of bad vacuum tubing. Didn't change anything. Got a cheap but effective smoke machine. Found the upper plenum was leaking at the gasket. Replaced gasket and confirmed the leak was fixed. No change. I have a decent but inexpensive scan tool. Watching the stft and ltft for bank 1 is crazy 50% and 25%. Decided to replace the fuel injection spider. Fixed and ran pretty good for a day. I also tested fuel pressure don't remember the exact psi but it was around 55 as I recall. Code is back and its running like crap at idle. It's new to me so I replaced the plugs and wires early on before this occurred as well as the fuel filter. The cap and rotor looked good (tm) so I didn't replace them yet. Not really sure where to go next. I am going to verify I have spark tomorrow but that's the last thing remotely connected to this I can think of checking.
Please help.
Check your wiring on the O2 sensors for chafing, breaks, corrosion, etc. I just went through 4x O2 sensors and new cats because I misdiagnosed an unplugged sensor and a severed wire on another.
Clean your MAF sensor and the IAC valve.
Check your fuel pressure again.
Hope this helps.
Howdy and welcome to the forum, Ned.
Thank you for serving. My brother was on the America before she was retired.
1 - 3 of 3 Posts
