Ok as I posted last week I bought a 216k Mile 2004 5.3L Z71.
I knew the cig lighter dident work (dident really care) but the truck was idleing slightly rough this I also knew, but their was no CEL. Running it today a CEL came on, put my basic reader on and no power, goggled and found that a blown cig fuse can cause no power to the reader connection and it worked, ran it and got a p0300.
Now the previous original owner "thinks" he had half or all the plugs changed at about 150k when he had a cracked head replaced but not sure. I have that "need a tune up smell" from the exhaust not completely rich smelling just that incomplete combustion smell. Air filter is clean, I just cleaned MAF nothing.
So my first step is plugs I ordered NGK IZTR5B11 Laser Iridium That are pre gapped .40. Should I use these? Return and get AC Delco Platinum? Iridium? Should I go with wires or see if plugs?
Other things I have read clean the flapper on the TB (wifes Mazda 3 would run rough after pulling battery due to carbon build up) and pull and clean or replace IAC Valve.
Any other quick cheap fixes before I get too deep into digging?
- - - Updated - - -
Scratch that put the NGKs In and AC Delco 9748HH wires I got from Advanced Auto and all is well running great under throttle and idle is butter smooth.
Stock plugs were the worst I have ever seen! They look every bit of 216k miles.........
- - - Updated - - -
ALSO cleaned TB while I was their
- - - Updated - - -
- - - Updated - - -
