My daughter is driving a 1992 Chevy Suburban and the brake light on the bottom right of the IP stays on. She stated that it has been on for a week. She stated that she hasn't used the parking brake at all.
When I checked the parking brake, the light gets a little brighter when you step on the parking brake and goes back to the intensity that it was when the parking brake is released. I checked the switch visually(this is the switch that has the copper arm that is engaged/disengaged by using the brake), and also with an Ohm meter just to make sure and everything is good.
I don't get any trouble codes when I scanned the truck.
Any ideas on what I should check next or possible problems?
Thanks in advance,
Lenny
Thanks in advance,
Lenny
