1 - 14 of 14 Posts
Shouldn't they last longer then 64K???? Are they covered by Drive line Warr?
Well I've beeen hearing some rattling under the front for the past week so I lifted it today and found I need a new Bearing/Hub for the front right.. Anyone have an idea where to get a GOOD one at a good price? And how hard is it to replace?
Thanks.. Glenn
---------- Post added at 05:22 PM ---------- Previous post was at 03:51 PM ----------
I was just going over the owners book and it says I should be covered.....For the front Hub Bearings... 5 years -100,000 miles... Is this true?
They should last more than 64K. The '96 'Burb had over 200,000 miles on its front hubs. I'm sure your warranty will cover it.
Spoke to a friend in Ga with a 07 Z71 Av. He told me that at 97K one of his went and they replaced them all... Nice So I will talk to the dealer Mon morning to see... I hope they don't give me BS because of my Rims and tires They are the Same size as the stock 20's you can get from the dealer..
· Super Moderator
If you have the stock wheels and tires I would put them on so theres reason for them to say no. If you don't have the stockers then do what I would do and kiss there butts up one side and down the other. LOL.
Discussion Starter · #6 ·
I will call them on Mon and ask the guy I know. If I have to I will put my stocks back on.. What a PITA!!! But if it will make them happy...
· Super Moderator
Thanks.. Glenn
Glenn.....below is from Chevy's Web Site the (Warranty Section), its Regarding the front wheel hub bearing's,
...Drive Systems....All internally lubricated parts, final-drive housings, axle shafts and bearings, constant velocity joints, propeller shafts and universal joints. All mounts, supports, seals and gaskets as well as any electrical components internal to the drive axle. Also covered are any actuators directly connected to the drive axle (i.e., front differential actuator, etc). Exclusions: Excluded from the powertrain coverage are all wheel bearings,Drive Wheel front and rear hub bearing's, locking hubs, drive system cooling, lines, hoses, radiator, sensors, wiring and electrical connectors related to drive systems as well as any drive system control module and/or module programming.
Chevy's Web Site,
http://www.chevrolet.com/owners/warranty/
My book in my hand says Drive systems Wheel Bearings and Locking Hubs are covered ?? Well I will be giving them a call soon...
Discussion Starter · #9 ·
Ok They say it is covered.. And no problem with the aftermarket wheels.. As long as they are within Spec of the Factory 20's Which they are..
Thats great there covered!!
Discussion Starter · #11 ·
I just took the wheel off to take a look.. Not nice.. and I have to drive 20 miles to the dealer.. Hope the wheel does not come off.. It is Loose...
Discussion Starter · #12 ·
Well got it back today.. All fixed They replaced the right front Bearing and said the others are fine and so are the brakes A little low but good for now.. Time to drive...... :)
Sounds good to me!!! I assume by your happy face there was no charge.
Discussion Starter · #14 ·
They charge for that ...... :)
1 - 14 of 14 Posts
