Replaced the driver and passanger side wiper blade on my 2006 Silverado Z71 Quad Cab - both blades are 22".
Both blades snapped in like a champ, but the blade on the passanger side doesnt sit flush against the windshield at the very tip. It almost looks like the blade is about 2" to long, but when I swap it out with the blade from the driver side, I get the same result.
When the blades are turned on, the lower right hand corner of the windshield (if youre sitting inside the truck and looking out the front) does not clear off the and the rubber of the blade does not make contact with the rest of the windshield until its almost at the center/top of the windshield.
I had to actually replace the arm about 3 days ago because of some ice damage and Im still getting the same result.
Are there any adjustments I can make to the arm or assembly, or did I read the manual incorrectly when it said to use 22" replacement blades?
Thanks for any info!!!!
