1 - 4 of 4 Posts
Okay guys i need help here fast! i was driving my truck this morning and it all of a sudden started this horrible squeeking sound! I had my windows rolled up and i could even hear it over my radio. So when i got home i pulled my drivers side rear brake drum off and these things just so happen to fall out with it! Could someone here please tell me what they are and how to fix this? i also included pictures of the ate up pad just for reference. I really need help here because i have never messed with drum brakes before. and also my truck is a 2005 chevy silverado 1/2 ton z71 Auto part Disc brake Wheel Alloy wheel Rim
Auto part Vehicle brake Disc brake Brake Wheel
Auto part Wheel
Auto part Automotive tire Rim Wheel Metal
Auto part Wheel
Holy crap, did you forget to release your emergency brake? I've never seen such distruction on a set of brakes. I would suggest getting a repair manual to get the new parts back together.
Nope the parking brake was completely off! lol i have no idea how this happened though. im guessing they are parts to the parking brake? Since this has happened though i put the drum back on with out repairing anything and my brakes are a whole lot more spongy feeling now that this has happened. The only noise it has now is the beat up shoe making a little noise on the drum.
The self adjuster appears to have dissasembled and fallen into the drum. You will probably need a drum, depending on the amount of scoring on your old one, a set of shoes, and the adjuster assembly. You will need a friend with knowledge of brake systems. There is a spring which keeps the adjuster from turning unless the "self" adjuster turns it, or a mechanically inclined person turns it. It appears this spring failed to do its job. Without this adjuster, the brake cylinder goes through excessive travel making the rear brakes ineffective. Fix it before you drive.
1 - 4 of 4 Posts
