1 - 11 of 11 Posts
So I went to pull off the spark plug wires to change out the 80K plugs originally in there and the wire, boot, heatshield, and coil shaped spring came off, but not the spade shaped connector because it was stuck on the plug. Is this normal, is the connector supposed to separate like that ? Can I just remove the connector from the plug, replace the plug, and then put the connector back on the plug then put the wire assembly pushed back on ? I noticed the heatshield has that spring in there, why ? Should I just fork out some more cash for a new set of wires and should I re-use those heatshields ? What brands of plug wires do you recommend ? I have the Bosch Platinum +2 plugs, what are your opinions of those ? Any help would be great, Thanks.
Welcome to the club. As many on this site can tell you GM's like A/C Delco plugs. They don't like any Bosch plugs. Also what year truck, model and motor do you have??
· Super Moderator
x2...on What STB has mentioned, In order for us (The Member's) to give you Advice and/or Help...........you really need to give us some more Information about your Vehicle.......Meaning what......Year....Model.....and Engine your Vehicle has.
Discussion Starter · #4 ·
Sorry to keep ahold of the info everyboby. It's an '01 Tahoe LT 4x4 with the 5.3. I picked it up for the wife last year and she loves it. I love it as well just because it doesn't come with a $500 plus payment each month. good truck, just trying to work out a few bugs and not go broke like the Feds. Thanks.
· Super Moderator
For Your 2001" Tahoe with the 5.3 Liter, You Want the A/C Delco Iridium Tip Spark Plugs......Which Are Gaped at.....0.40 during Manufacturing, Carefully Check to See if They are Gaped Correctly at (0.40), But if the Gap is Off, Do Not Attempt to Re-Gap Them......and the Reason is the Iridium Tip can be Easily Damaged.....Take Them Back and Get a New Set.
I went to my local Napa and got their Denso wires, very pleased with them
get new wires, you will be better off, if you are changing the plugs you might as well do the wires too. I just got some from summit racing, pretty cheap and they are 8mm
Do yourself a BIG favor and get some silicone grease and lube up the inside of the new plug boots along with the other suggestions. I have also found it extremely usefull to use one of the old boots placed on the new plug to start it in the hole. This does two things for me. First is to give a better grip and secondly if the plug starts cross threaded it will slip and not damage the head and you get a second chance. Good luck.
1 - 11 of 11 Posts
