I need some advice. I dont' know if this is just my inexperience with diesels or a potential problem brewing.
I've noticed that once temps hit 80F or more my truck is running at about 210F instead of 185 (this is also the case on the highway with cruise control set at 70 - 2K RPM). The transmission oil temp will clime to the 200F mark, but usually stays closer to the ~ 170 mark (whatever is the normal op temp).
My concerns: Engine is not cooling to it's normal operational temperature even when cruising under no load. The coolant was changed out recently (about 10K - 15K miles / 4 months ago). Coolant levels have been consistant and there is no smell of coolant leaking.
Is it normal for there to be about a 30 degree temp difference between the oil and trans temps? I had read somewhere that the oil and trans temps sould be almost the same and shift consistantly together. If not, what could the problem be?
Thanks for any help.
