1 - 1 of 1 Posts
Can I do a "power" transmission oil change on my 2002 Suburban. I also own a 2002 Ford Taurus and they have a procedure (in the Ford factory manual) than involves disconnecting one of the oil cooler lines and running the engine until transmission fluid stops coming out. It gets most of the transmission fluid out, including the oil in the torque converter.
Is there a similar procedure for the GM 4L60 transmission?
1 - 1 of 1 Posts
