1 - 8 of 8 Posts
I cannot seem to find the proper torque for the 14 mm bolts on the Auto Transmission Crossmember. The 4 bolts that bolt the crossmember to the frame.
It is for a 2003 Tahoe Z71 4x4 with the 5.3. I have set it 80 Ft/Lbs right now, but I hope that I can get the correct torque before I take it off the jack stands.
This is where the transmission mount bolts to the transmission and then to the Crossmember in question.
Also, is it true that the trans mount bolts are only torqued to 18 Ft/Lbs??
Thanks
Im not sure but when I put mine back on I put the impact on them and called it a day haven't had any problems with it in a year. Not too sure about the trans bolts either don't have a service manual to look at.
Yes the trans bolts are only 18ft lbs. because of the aluminum housing. Just put some blue lock-tite on the threads.
Be careful,may be goodenstripped.LOL.
1 - 8 of 8 Posts
