well i just got the new toy a 1983 27' motorhome. My inlaws and I rebuilt this beast. she got a new is a 572ci/720hp/685tq motor with 12.0-1 compression ratio. my father would not listen and put in a dual flex-a-lite fan and one motor burned up. i done a ton of Ford Taruas fan swaps and going to do one on this beast. i can do a writeup as the steps are the same. this fan is the best performance fan out there and costs $10-20 at any junk yard. they got 2 speeds high and low and on high will flow 4500 cfp. i even setup 2 of these in the garage to cool it down when it gets hot. i set these up to run high only or low only and switchable to start low and if ac turns on then swap to high...i never get over eats anymore. so if you want a picture writeup i will or i will just post it over on the bronco club again.....mike
