1 - 4 of 4 Posts
my 2002 suburban 93k miles has very quick almost darting steering. It also seems to have a hitch in the steeering. Driving if I trun the wheel to the left there is a hitch of 1/8 to 1/4 inch in the steering wheel- it then release and the vehcile darts. My front end mechanic cannot find the problem. Any thoughts.
thanks
chuckj
Hey Chuck, welcome to the site!
If I remember correctly some of those Suburbans had a problem with the u-joint in the steering shaft that would cause a problem like what you are describing. Might check that out.
thanks
OTE=GaryL;44584]Hey Chuck, welcome to the site!
If I remember correctly some of those Suburbans had a problem with the u-joint in the steering shaft that would cause a problem like what you are describing. Might check that out.[/QUOTE]
Is the problem only in one direction? If so it may be in the variable ratio steering assy, it is electrically controlled. I had a similar issue that thankfully turned out to be a bad connection.
1 - 4 of 4 Posts
