1 - 9 of 9 Posts
Stabilitrak service light/traction control and reduced power:
Min started bout mid November and then quit? Then cpl weeks later it did it again for cpl days then quit, now it’s back at it again!
I hve checked wiring, plugs , compression, firing , every thing I hve seen on other forums, my question it why can I be driving kick it in passin gear and it quits all the problems? Then cpl weeks/days it does it again!
Discussion Starter #4
It’s an 07 1500 crew cab ltz, it runs fine then the bells start ringin and lights flash and starts acting like it’s missing (reduced power ) then it quits and no lights or warnings and runs smooth as silk! This time I hve noticed buzzing sound out of stereo and the passenger side heat /ac controls are on when I start it
Have the diagnostic codes read. Write them down so you can post them here.
Ted
Stabilitrak and traction control then reduced power and can't go over 25. Three different shops, three different SetS of answers. Nothing has worked.
What sensor/fuse/ wiring job can be done to have stabilitrak and traction control of worked out of the whole equation to just "bypass" the crap!??!
It's probably the Throttle Portion Sensor.
It's mounted on the throttle body.
GM has/had a special warranty on this item, they may still be offering the warranty.
If they are not, the part is only around $30
1 - 9 of 9 Posts
