1 - 2 of 2 Posts
2009 Silverado LX 1500 Ext Cab 5.3 4WD
I have spent a little time searching the forum but I just could not come across my exact problem. I have a 2009 Silverado 1500 ext cab that the RCDLR fried on. Not sure why but the fuse popped (#25 DSM) and I replaced it and the module burnt up , a resistor on the board was toast. I inspected all the wiring and found nothing wrong so I replaced the module with a new one, the fuse did not blow with this one. I scheduled an appointment with the local dealership to have it flashed to my VIN and they said they couldn't do it because my remote was bad, the remote is not bad because I programed it to another pick up and it works fine. When you hit the check mark to go into learn mode the display just flashes back to enter learn mode screen. Also, after the dealership tried to flash the module I lost the auto door lock feature in the dash but the auto door unlock is still there. Has anyone ever ran into this issue or know what this could be? Thanks, Chris
Discussion Starter · #2 ·
and other modules and found B2555-01 and -02 on DDS and B2555-
1 - 2 of 2 Posts
