Item title: 1998 98 GMC Suburban Remote Programming Instructions
1. Locate the Data Link Port. It is located under dash drivers side.
Be sure you
know which pins are 8 and 4.
(Notice port is wider on top row)
2. Make sure there are metal contact pins in terminals 8 and 4. Connect
8 to 4
with a suitable jumper wire (leave the jumper wire connected throughout the
programming procedure). Make sure you know which terminals are 8 and 4. The
vehicle will respond by locking and unlocking the doors to signify entering
of
programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first
transmitter to be programmed. After about 15 seconds, the vehicle will respond
by
locking and unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters
to
be programmed.
5. Remove jumper wire applied to the OBDII Port.
Be sure you
8 to 4
of
programming mode.
by
to
be programmed.
