In the prociess of removing the rusty rear brake line, I jostled the rusty fuel line enough to put a crack in it...I now have a fine mist of fuel that sprays all over my back axle...it would make a perfect torch if it somehow sparked off!!
So it is time to remove the fuel tank so I can replace the hard line. I wanted to check here for tips before I start. Besides removing the fuel from the tank first..any suggestions about dos and don'ts? Judging from the weight of my 20 gal fuel tank of my 71 pontiac..I assume this thing is a beast..can one person remove it safely from under the truck?
My sub is an 89 3/4 ton and has the skid plate around the tank..I seems there are 3 bolts holding the skid plate up?
