1 - 2 of 2 Posts
Hello
My stock radio plays at low volume and cuts out if I turn up the volume to moderate levels. Then it will only come on at the highest settings unless it resets itself. Instead of repairing it I would rather replace it with another OEM radio and wanted to know the tools and procedures to remove that radio and replace with the same.
Thanks
Joe
If I can recall right on your year, pop the trim panel off it just snaps into the dash, then all you need is a 7mm 1/4 drive to take out the screws, then unplug and plug the new one in and your good, the only issue would be if it has the theif derterant stuff on it, if so you may have to get the code and reset it
1 - 2 of 2 Posts
