Timken or skf for brand of choice. As for special tools, you just need a socket big Enough for the spindle nut. There's is 3 bolts that hold the hub assembly on the spindle from the rearIn a couple of weeks I'll be replacing all my hubs and bearings on my 2001 Silverado 1500 2WD. Are there any tips or tricks I should know and, more specifically, are there any special tools I'll need? Everything is stock/OE.
No disrespect taken. i can certainly understand needing to take it easy on the pay check. I've never had an issue with timken or skf bearings. Working in a parts house myself for 10yrs has given me a damn good perspective as to what's worth using or not. Autozone a valuecrap line is exactly that. I've never had anyone return them because there was nothing left to return, but ive certainly upgraded many of them came in complaining about them. Same for pep boys value line. I can't speak for oriellys value line as I never used them or knew anyone that did.With all-due-respect to what's been previously recommended ~ Look a little deeper and You will find yourself weighing the cost-difference between those brands mentioned and what's being offered from the likes of "China", etc., @ sometimes more than 1/2 to even less-than 1/3 the cost...
I've asked Parts Suppliers what the failure/return-rate is between "brands" and -- at least according to those I've spoken with -- "It's really not that much different..."
That said, I'd rather support Our "American Made" economy over those of foreign Nations ~ but I also have to pay-the-bills at the end of the month, including those incurred for keepin' My wheels rolling...sometimes that's what I have to do in-order remain around to "Fight another day" ; )
Perhaps Others here will chime-in with Their perspective(s)... : ?
BTW ~ Be SURE to use a drop of RED "Lock-Tite" on the first few bolt-threads AND a known-accurate Torque Wrench on assembly ~ to insure BOTH: The recommended tightness of those bolts keepin' the Hub stayin' ON until the next time YOU want it off ; )
