Unless Chevrolet has made a big change since 99, all you need to do is remove the trim bezel around the cluster, the cluster is held in by 4 screws, remove them and you will be able to remove the cluster. The lamp socket twist out and the buls pull out of the socket. The only ones I have seen that need soldering are the ones in the radio. Take your time and you will do fine.
