1 - 7 of 7 Posts
Welcome dflahe, I found a technical bulletin.
Make: CHEVROLET
Model: CHEVROLET TRUCK
Year: 2003
Service Bulletin Number: 031803
NHTSA Item Number: 10001891
Summary Description:
A CLUNK NOISE COMING FROM UNDER THE HOOD THAT ALSO CAN BE FELT IN THE STEERING WHEEL. *TT *JB
Service Bulletin Num : 031803 Date of Bulletin: MAR 18, 2003
I hope this helps you. BTW It says something about replacing imtermediate steering shaft, check with dealer.
The TSB was revised last year. What they do now is remove the intermediate shaft and use a grease pack in it. It works for a few hundred miles if you are lucky. I would ask them if they do the grease kit again what they will do if it doesn't work. When I worked for GM my dealer would do the grease kit twice then replace the shaft if it failed a third time. My 04 and 06 Silverado had the same noise and I ended up replacing the shafts. Hope this helps.
1 - 7 of 7 Posts
