1 - 13 of 13 Posts
I have a 2011 silverado with 5.3L. I noticed these two messages flashing at me and I can't get them to turn off with manual reset instructions. Is the dealer my only option? Is there something I can fix?
Tim
· Premium Member
How many miles on this? You said these are flashing messages, or is that just a figure of speech?
I have had the issue twice in the past on my 08.
The first was caused by a "tech" lifting the truck and catching a wheel sensor line pulling and damaging it. The lights were NOT on when I shut truck off at dealer, but were on when I started it to pick it up. Then the "tech" said, "they were on when I pulled it into shop...." Yeah, uh I was there on full warranty, ya think I may have mentioned it??? I no longer use that dealer.
The second time the symptoms were accompanied by a harsh 1st to 2nd shift. After much troubleshooting by my new dealer, who is awesome, it was found the wire bundle behing the brake assembly(power adjustable) was chafing and shorting. I believe there is a TSB on that issue.
XS ive,
Do you have any idea what the TSB number is on the chafing harness? I have similar symptoms on my '07 Suburban. The Stabilitrak light comes on when coasting, like when coming up to a stoplight. It usually clears within a minute or so, but if I start out while it's still on, then the shift to second is very hard.
Tim
Mental note for me.*check year model of vehicle*-Check
*has wheel cylinders*-check..
*issue is something with that year model*-check.....
Okay I'm good to ask a question on brakes now!! Hahaha (only a few will get this if they read it)
Anyway, have you recently had your brakes serviced for repaired for any reason?
I read below that they stay on solid. Have they always stayed on solid or did they come on and go off under throttle or braking?
XS ive,
it was bulletin 08-07-30-021F
I think you have a problem with the throttle position sensors on the throttle body (it's actually the motor that operates the butterfly). GM has extended the warranty to 10 years. I had mine changed last month. works fine.
Read this thread, it has the TSB number in it. http://www.gmtruckclub.com/forum/sh...ne-Power-anyone?highlight=Service+Stabilitrak
Thanks for the tip. I'll check the codes and see if they line up with a TPS. The service bulletin (11273) only goes back to 2008 and mine is a 2007. And I've never seen the Reduced Power message or felt the effects either - just Stabilitrak and Traction Control. I'm wondering if it might be something else.
No prob, Alan, actually, I thought I was answering the op, he has 2011. Your right, the 2007 Silverado is a different truck and the TSB would not apply. But, other than the Reduced Power message, your description is the same.
Hi Alan,
I’m sorry to hear that the Stabilitrak light comes on in your vehicle while you are coasting. We will be glad to search your VIN within our system and see if we can find anything pertaining to your concern. If we can be of any extra assistance, please send us a private message referencing this thread. I look forward to hear from you soon!
Kristen A.
GM Customer Care
1 - 13 of 13 Posts
