1 - 2 of 2 Posts
:( I bought a 2006 Silverado half ton regular cab back in February and since I bought it, it has had an alignment problem. When you keep the truck straight, then let go of the wheel it goes to the right. If you make the wheel straight it goes to the left. I took it to a certified Chevy dealer and they were supposed to fix it, they only made it worse. Has anyone else had this problem?? Is there a lemon law in Ohio or anywhere? Please let me know!! Thanks for reading! --Tonya
Steering column. Pop the hood and look where the bottom of the column is joined, then bolted. Take the piece that is joined and bolted and see if it wiggles. it is not supposed to move at all. Thats all I got, hope this helps...
1 - 2 of 2 Posts
