I'm not necessarily looking for a Rancho. I would actually prefer one that's not branded at all. I'm more asking about skid plates that will actually work with the Fabtech.Why would you want to have a rancho Skid Plate with a Fabtech Lift? That doesn't make sense to me? Just curious...:lol:
Oh okay that's a pretty good idea then!Rockstarr, the reason for the double skid plate is for more protection and they reinforce the front suspension when off-roading. If you look at my photo album you can see the Rancho skid plate thats at a angle, then the Skyjacker plate is mounted flat under the suspension subframe so the two skid plate blend into each other. This works great when rolling over logs, rocks etc...
Thanks for the tip. I'll check that out.Hey jmanb, take a look at the BDS suspension kit for your truck. It looks like the skid plate will work with the Fabtech kit. Might need a little modification. Most likely you will have to special order it seperately from a BDS dealer.
