1 - 4 of 4 Posts
Okay so I have a predator installed on my truck and my truck is due for smog testing am I going to have any problems when I take it in? because I was thinking should it create less emissions since the programmer helps with MPG?
Just set it for Stock. You should have no problems....
· Premium Member
Does your predator have a CARB certificate?
If it does you should be ok, put the settings back to stock before going to the test site.
If you dont have the CARB cert. make sure theres no sign of it being used on the truck.
1 - 4 of 4 Posts
