1 - 12 of 12 Posts
I am having a couple issues on my truck but I thought I could address them separately.
Always.
From a stop if I floor it it really goes slow and take a 1/2 block to get up to speed. But if i ease into ti it gets up to speed faster.
(The rpms stay low and it has no power)
similar issue
Sometimes.
(The rpms go really high and it has no power)
could these be related or separate issues?
Check your fuel pressure and your fuel filter.
I don't see which vehicle you are running, but I believe those values are low in general.
Yeah, severely low. Runs way better scratching around that 60+PSI mark. New pump time.
  • Like
Reactions: xxxzodiac
Discussion Starter #10
Finally got a code reader.. 1 Left front oxygen sensor bad. 2 knock sensors bad. (I was told my throttle body is whats causing the delay.
Did you fix the fuel pressure issue? Because the low pressure will cause the delay and symptoms you are describing.
I would not start with the throttle body.
Discussion Starter #12
Well the throttle body is easier to fix than the fuel pump. It is a fly by wire not direct so that make a little sense. I swapped out the throttle body and it seems to have fixed the hesitation problem. time wil tell if the hesitation after warmed up and driving all day problem stops. I ordered and received a new exigent sensor i will swap out when have some time.
1 - 12 of 12 Posts
