1 - 7 of 7 Posts
hello everyone. i am in the navy and work in a show full of mechanics and no one can tell me for sure what is wrong with my ac. i have a 2001 suburban and for the most part my air conditioning works fine. however when i have been driving for a while and i end up getting stuck in a traffic jam my ac wont work as usual. the air will still be slightly cool but humid. very uncomfortable to the point that i would rather have my windows down with the dam 115 degrees temp out side. same thing the other day i drove on the highway for bout 2 hours and the ac worked fine but when i stopped at the micdonalds drive thru same thing happened with the humid air. i know its not the outside air coming in because like i said the temp outside is real hot and the air that will come thru the vents will be a little cool just humid though. when the ac messes up due to going real slow or going idle, if i end up going back on the freeway going fast speeds the ac still wont start working for sometimes about an hour then maybe it will start working depending on how it feels. also i dont know if it makes a difference but i have been noticing that the force that the air comes out of my vents changes sometimes. if i set the ac to a 4 sometimes it will feel like a 2 or 1. i have already checked my clutch and it is spinning fine and i changed the ac relay but to no avail. if anyone has heard of this or has some help for me please help. thanks for any help.
You will want to check the pressure in the AC first.. also it sounds like you may have a plugged drain for the AC, an or else a weak compressor as well.. but check the Pressure in the AC system and go from there.
X2 on the drain possibly being plugged & giving you the high humidity. As for the change in air flow from the vents, even though you haven't changed the fan speeds, this sounds like the evaporator is iceing up & is probably due to so much condensation in the evap/air box.
Discussion Starter · #4 ·
checked the ac pressure and is all good. drain seems to be working good. i dont understand how it would be frozen over though. like i said i can drive all day and its fine until i get stuck in a traffic jam or something that has me going real slow of even sitting in idle. please anymore advice.
I'm not a A/C person, but do you know if your 'Burb has a cabin filter? If it has one has it been changed. Years ago I changed my filter in my'96 'Burb and that seemed to help with the cooling. I wasn't having any issues with the A/C but I changed it as a maitanance item and it did seem to help cool the 'Burb quicker. just a thought.
The 2001 Bubans do have a cabin air filter. As to the icing up it will happen when the pressure drops etc.. it sounds like you may have a weak compressor, or something along those lines.. if it does it try to turn off the AC, for a minute or two then turn it back on.. since i had the same issue in my 1998 ac and that is what i had to do that.
when the cooling messes up i do turn off the ac but it wont start working until sometimes about a hour later. i guess the compressor sounds like a good place to start so far. hopefully a get a few more ideas by next week when i change out the compressor
1 - 7 of 7 Posts
