Tom....
You will find screws under a small plastic cover in the arm rest/ pull handle.
Depends on the style of interior, if you have pull strap/handle there will be screws under the small plastic caps on each end.
There maybe a screw in the door handle area, again depending on the interior style, plain..to extensive.
If you have map pockets, along the bottom of the door panel, them may have screws in the corners of them,
Then...yes you need to start on the bottom and gently....gently pry the panel off....there will be the mushroom plastic cones holding the door panel.
Most importantly...go slow and careful and you will have good success!!
