I got my '90 suburban last summer in Texas and drove it all the way home. The speedo was stuck at 67 most of the way and sometimes even went back to 0. It even started working for about 5 minutes. I just put it on the road yesterday and forgot about this problem (I also forgot to reinstall the rearview mirror and seatbelts). Is it a bad speedo or loose connection?
With an older model (90) its all mechanical, it could be the cable, speedo gear at the trans, or the guage cluster itself. I'd try lubing the cable with graphite first then check the gear at the trans. Last would be the guage cluster.
Newer models are electro mechanical. These have had problems since the early 2000's. Saddly GM has'nt thought enough of the problem to do a voluntary recall and NHTSA has'nt forced them to do a recall.
Discussion Starter · #4 ·
That's what I figured. I spoke to my grandpa a while ago and it is just too damn cold right now to fix it.
Super Moderator
I don't know about the '90 model, but I know for a fact that my '91 speedo is not mechanical. It pulls off the same sensor on the tranny as the rear wheel antilock brakes.
