Yes, and thank you, It's the original and I didn't lay down to measure it, But I have a set of Summit shorty headers going into the original ' Y ' pipe which is a 2.5 pipe and on the exporting end is the Gibson 3" exhaust pipe ! Does this make sense to you ? I want to replace it with a 3" and 3" high flow converter. Thank you !Jt I assume that your old cat is gone. Why does the length matter if you have to cut and weld the new one in anyway? Do you have a test Pipe in there now that you hope to just swap with a new cat? Just curious.
I installed the Edelbrock intake manifold #3704 and the first few days it had a ultra- hesitation , but that cleared up after a few days. Now on that end, when we did the engine we changed the fuel injectors and I got a 'Matched Set' from a company that does a lot of injectors and that work OK as we put a new O2 sensor in 'Y' pipe, I think it was in the pipe and not the manifolds. I thought if the intake is using more air/fuel mixture, then it would balance out with increasing the exhaust flow ?I don't think you overload the ECM but I can't say for sure if your ECM can be tuned as I'm not that up on it. I do know that when you change from stock intake volume and exhaust you end up changing the parameters around which the ECM and motor were calibrated. Since you are changing the flow characteristics in and out it would seem to me that a change should be made to the fueling tables in the ECM. Hopefully the ECM you have can be made to correct for any changes to the intake and better flowing exhaust. Also, I know from others telling me that if you eliminate too much back pressure from the exhaust you loose some power and torque. Just me thinking out loud.
I'm curious. How does your state know you are driving less than 5K a year. Good luck.
Yes, but it can learn or right ? I ask because the slight lag after the Edelbrock manifold seems like it compensate for the change and the lag is gone ?1990 is obd1 and can not be tuned like an obd2 vehicle
