1 - 2 of 2 Posts
Ok, so this may seem a little odd, but whenever I disconnect my negative battery terminal to do work on my truck, the head unit (Alpine CDE 103-BT) does not turn on, even after I have reconnected the battery wire to the battery. I press the power button on the head unit and nothing happens, I pushed in the reset button on the back; nothing. What really stumps me though, is that in order to get the radio working properly again, I have to disconnect and reconnect the big gray plug that all of the wires from the head unit attach to. After I do that, the head unit works fine. Any thoughts on what would cause this? My friends nor myself can figure out this issue lol.
Might be because the radio is always pulling current, and without the main ground may be using a ground within the radio itself and somehow locks itself up. I would try and pull the radio fuse, wait a while and then put the fuse back in. If it turns on fine then it's something with the radio and only the postive hooked to the battery.
1 - 2 of 2 Posts
