1 - 14 of 14 Posts
ok so my pass window wont move, or the seat and driver seat also.... what and where to look? 03 silverado Thanks guys!!
If the passenger window does not work I would suspect the window motor. this would be with using the master and door specific operating switches. on the seats both not working I would check for fuses.
1997 Chevy Cheyenne K3500, cc, lb, dly, dzl, 2002 Chevy Avalanche Z71, 2003 Chevy Avalanche Z66
I was going to suggest looking for fusible links somewhere in the hot power line for those circuits. For the window - a corroded switch could cause it to stop working also.
My two cents. Hope you get it fixed.
Discussion Starter #4
All of it stopped working at the same time
so ever time you operate your vehicle you operate the seats and passenger side window ?
I would get a volt meter and start checking fuses and also the feed to the window motor when the switch is hit.
Discussion Starter #6
Family of 6...you tell me lol
Discussion Starter #7
it was a red fuse
a red fuse is 10amps. just would like to know the fuse name . the passenger window and the seats now work with the replacing of this red fuse is weird.
Remove all fuses that say ecm there is one at side door fuse panel and I believe two under hood panel let sit for 10 minutes reinstall fuses and turn iginition on for 5 minutes do not start then turn off ,now start truck and u should be good to go
Moderator
Instead of doing that why not just disconnect the battery for ten minutes?
For some reason it will not usually work with just battery disconnected I tried it and it was a no go, there is a right and left ecm fuse and it needs to reprogram but not loose total power to computer
@badss98, I might buy your fuse theory if you were talking about the Body Control Module (BCM) and not the Powertrain Control Module (PCM). The PCM should not impact things like windows, or seat (maybe the seat of your pants, but not the seat you sit in).
I don't have a wiring diagram for that truck, but it probably has a fuse panel inside the ruck. The internal fuse panel usually controls the "creature comforts" things in the cab. This panel is fused from a large (size and amperage) fuse in the main panel under the hood. Check the big fuse.
If you continue to have problems. Check the circuit breakers in the panel on the drivers side of the dash. If you have memory power seats, There is a whole list of things that go wrong. The most common is the module under the seat has a massive "brain-fart" and will need to be replaced.
1 - 14 of 14 Posts
