The odometer is acting strange [Expired Topic]
1569 Views 3 Replies 3 Participants Last post by  Davandy
When I drive on the highway and I use my turn signals the odometer jumps up and down. :roll:
Does anyone have an idea what the problem is.
Thanks,
Status
Not open for further replies.
1 - 4 of 4 Posts
??? I've never heard anything like this happening before. What do you mean it jumps up and down? The numbers go higher and lower, or the contrast/brightness goes up and down?
Everything is electronic in the cluster, Fieros have a lot of problems with bad grounds and do a lot of things like this.
Try putting an extra ground from the battery to the engine and one from the engine to the firewall.
Electrical problems SUCK!. :evil:
Dam I can't spell. :oops:
:idea: Didn't you just change motors or something? :idea:
If you missed a ground or didn't get a good ground this could be the problem. :D
Ok I will check every connection maybe I mist one. :oops:
Thanks
1 - 4 of 4 Posts
Status
