1 - 6 of 6 Posts
Does anyone know what to do about a Third Brake Light Problem..??
I have a 1999 2d Tahoe, the Third brake light on top WON'T STOP FLASHING...I replaced the Flasher
Twice....It is on as soon the engine in on...ONLY when I step on the brake does it stop flashing..!
EVEN my local mechanic was kind of lost after replacing the FLASHER...
It's freaking annoying....NOT to mention catches the eye of evey COP...!
ANY IDEAS WOULD BE GREATFUL....THANKS Very MUCH...
_Northern California..!
PS: I can't just remove the flasher, because it also controls the SIGNALS...
Temporarily remove the bulb. Check emergency flasher system. Not sure but sounds like brake and flsher wire crossed, got trailer wiring? Check there for crossed wires. Do regular turn and brake lights work O.K ?
Thanks for the response...
I don't have a trailer hook up...
Both Signals work fine and so does the Hazzard swith....
Just the Third light on top starts flashing when I start-up...and stays on untill I press the Brake
pedal then it's STOP FLASHING...!!
Still have no clue....I thught maybe the switch by the Brake pedal going bad..(GONE BAD.)..??
Just the THIRD light is flashing, the other brake lights are fine...
When I press on the brake the all three brake lights stay on, but when I release the brake the top third light
starts flashing and others are off....Still thinking maybe it has something to do with the brake light switch
by the pedal...but NOT sure...
1 - 6 of 6 Posts
