I have noticed recently that when I accelerate and I am cruising, I hear a ticking sound similar to an oil tick. this noise is deffinitely coming from the wheels, and when I apply the brakes it stops. Any thoughts? the noise gets faster as my vehicle gains speed.
Thanks,
Greg.
what year is your TB? When was the last time the brakes were done? Do you notice any pulsing when you brake? This kind of sound happens alot when a rotor is just slightly warped. The ticking sound comes from the rotor knocking the brake pads against the caliper every time the warp spot comes around. If it's been a while since the brake were done or your feeling any pulsing when you brake (even if it's very slight) it can cause this and a simple turning of the rotors will fix it.
GMMan4ever
MY TB is a 2003 LS 4x4 model.
The dealer said they had seen 3 or 4 TB's with this problem. Lucky me. Thankfully, I had an extended warranty, so a $1600.00 repair cost me $200.00 (deductible + wheel bearings that were not covered under the warranty).
Good luck !
