I have a 2002 Suburban with a limited slip differential. It has 127,000 miles. I'm starting to hear some differential noise under drive conditions. I don't hear any noise in coast or float conditions. I currently have Mobil 75W90 Synthetic lubricant in the rear end. Can I go to Mobile 75W-140 synthetic lubricant without affecting the limited slip mechanism?
I have never towed with this vehicle, but don't know what the PO might have done. It has a trailer towing package, but did not come with a trailer hitch.
I have changed the lubricant viscosity on a number of cars with pretty good success, but none of them had a limited-slip differential.
Any thoughts?
Thanks
I'd stay with the 75/90 and try to track down the noise. Have you tried jacking up the rear on jackstands and have someone listen for the noise?
There is an additive for LSD diffs that you should be running.I have heard that using synthetics with an LSD and no additive can cause damage.I had a tundra that required 90w oil and had to put the additive in with a synthetic but I cannot remember the exact reason why.
No additive required with M1. You could try running the 75-140 and see if the noise stops. The heavier lube will only hurt economy. The front pinion bearing is probably going out. Not uncommon with a 10 bolt that has been running low on Dino.
Discussion Starter #5
Here is what I have done so far:
1. The lubricant has not been run low. The lubricant level was right on the full mark before I recently drained the differential.
2. Synthetic lubricant is what the owner's manual specified. No mention of additive
3. I added GM 1052358 when I recently changed the lubricant.
4. I have had the vehicle up on jack stands and listened to all the bearings (pinion, differential side and wheel) with a mechanic's stethoscope - no unusual noises.
I'm beginning to believe that the problem is the ring gear and pinion since this noise mainly appears under thrust conditions and not float or coast conditions.
