1 - 3 of 3 Posts
What PSI should I be running in these tires. I purchased the Tahoe with these wheels and tires, and the size is no where close to what is marked inside the drivers door. The max pressure marked on the tires is 51 psi. Thanks for the help.
I would keep them at about 38-42 PSI's
I know this isn't the quick answer you were looking for, but it may be a better solution overall.
Whenever I have a problem like this, I got to Discount Tire. They are always professional and helpful, and they don't charge for advice. I have to sometimes store vehicles for long periods of time. Of course the tire pressure is often off in at least one tire when I remove the vehicle from storage. In that case, I pull into Discount Tire, ask them to check the pressure on my tires (if it's off they fill them up) and roll out. They never ask for proof you bought the tires there or anything.
1 - 3 of 3 Posts
