1 - 18 of 18 Posts
i have a 3.42 in my 2011 5.3 liter silverado z71 . Now I am wishing i got the 3.08 gear for gas mileage. How does changing tire size effect axle ratio? can i get a tire size that make my truck act like I have a 3.08 gear in it. my last truck was a 2wd 5.3 liter with a 3.08 and got much better gas mpg. I know having a 4x4 crew cab vs a exted cab 2wd will effect mpg. but not that much. any thoughts?
Super Moderator
Using a little algebra and this formula, you should be able to figure out what you want:
original tire diameter in inches x gear ratio = new tire size x new gear ratio
so, if you start with a 29" tire with 3.08 gears, and you want to move up to a 32" tire, what's the new gear ratio needed to keep the ratio.
29 x 3.08 = 89.32
89.32 / 32 = 2.79, so that's the new adjusted gear ratio assuming the gears did not change in the axle.
If you do go with a taller tire make sure you get the trucks computer adjusted for the larger tires so the trans will shift properly.
as stated above the speedo and stuff will be off with bigger tires, but also realize by going to a larger tire for a higher effective gear ratio you will lose some of the performance but you should see some increase in highway mileage due to lower rpms.
Maybe I'm a little confused here, but I can't see how a larger tire will do anything to help fuel mileage. Larger tire/more rotating mass = mpg loss.
you will see that more city wise (starting in traffic etc), but if its a nice highway tread tire wont be too bad on the highway and could help. at that point has a lot to do with the tire as well. going with a larger high void off road type tire will just bog down the truck and less mileage.
For what your going to spend in tires, I would swap out the gears!! :party: What is your mileage now?
I had 3.23 gears in my 08, changed them out to 4.11's.
I get about the same in town as before - 14-15mpg....if I take it easy I have gotten as good as 16mpg. Highway I got an average of 18 on a trip from tucson to L.A.
I still have the 3.23's if anyone is interested. 10 bolt 8.5
Discussion Starter #8
I am looking to just go with a bigger tire on the same rim. So yes there would be more mass but not much more as with rims and tires. If i did all my math right I have 265 60 r18 on the truck now, thats a 31" tire and a 285 75 r18 is a 34.8" tire and would give close to a 3.10 gear which is close to what i want. But its hard to find a tire that size that doesn't cost too much.
And i dont not want to change the axle the truck is to new for that.
To new for gear change but not for tires? Ok- I guess you could always sell your other tires to off set the cost. What kind of mileage are you trying to achieve...maybe you should be looking at other options.
IF you could fit those tires, your mileage will suffer all the way around.
Discussion Starter #11
why would it?
---------- Post added at 02:33 PM ---------- Previous post was at 02:31 PM ----------
the truck is getting around 12 in the city and 15 highway. my old truck would get 15 city and 20 highway
why would it?
you mentioned getting 35" tires, which is why. 1 they wont fit without a 6" lift (I think Rancho says 35's with there 4") thats why. And yes going up to a 35" tire will kill your mileage. goes back to the weight. I had 3.73's in my truck and went from a 31 to a 35 with a lift and I switched to 4.10 gears and it is under powered in hills and city but maintained my 12mpg that I was getting pre lift(since I do 85% highway which is why I only went up to 4.10). If I would have left the 3.73 I would have been gutless so with you even taller gears your truck will really struggle with that size tire, and I have the 6.0 4l80e etc. In my previous posts I didnt realize you were trying to go that big.
All other things being equal, increasing the width of the tire will reduce economy. Going taller will reduce engine rpms just like a gear change. But if you have to go wider to go taller, it will be a trade off. Also, raising the truck higher in the air by running taller tires will reduce economy too.
I would look at a custom tune, and possibly changing driving styles/habits to improve economy.
Your indicated MPG sound very very low for a half ton truck. Those are bad numbers for a 3/4 ton. Do you have a heavy right foot? How fast do you drive on the highway.
Discussion Starter #14
I know a guy that has 35 with just a leveling kit and he has now issues with them. Also with my last truck which was a extended cab with a 5.3 2wd it had 3.08 rear and it wasn't gutless. i do agree about the width of the tire cutting down on mpg.
I haven't had much luck find any tire that are not going to cost a arm and a leg to get.
That's why.
Discussion Starter #16
i have tried but the mpg on this truck compared to my last truck is night and day. I could get 20 out of my 2wd truck on the freeway doing 75 to 80 all day long and if i babied it between city and freeway it wasn't bad. I just didn't the a 4x4 would be that bad and was thinking it had some to do with the 3.42 in this truck.
I would maybe consider a custom tune for mpg over tires.
I too bought a 4X4 crewcab 5.3 engine with 3:42 gears and came with 265/65/18 tires. I also have a 2wd 5.3 engine excab with 3:73 gears.
I really didn't expect the 4X4 to come close to the mpg the 2wd has. I wouldn't pay much attention to the EPA estimated figures either, they are garbage.
I did lift my 4x4 2 inches in the front and 1 inch in the rear and installed 275/65/18 tires with a more aggressive tread pattern plus the c.c is heavier.
I just drove my 4x4 from southwest Louisiana to Daytona beach FL and back (about 1600 miles) and got about 16.5 mpg. Thats about what I expected. Going from 2wd to a 4x4 and expecting similar fuel milage is pretty much a heart breaker. Too bad you already dropped the coin on the 4x4 to figure that out.
Good luck my friend.
1 - 18 of 18 Posts
