1 - 7 of 7 Posts
Hi.
I have a 1990 Chev Suburban V1500 4x4 5.7. The door label says the stock tires are 235/75/15, but the truck has 31x10.5x15. I'm planning to buy a travel trailer (maybe 28 footer) and was wondering if I would be better off putting the standard size tires on for better towing performance, or if it will make much of a difference.
Also, I assume it has the stock gear ratio, but how do I check what that is? Is it encoded in the VIN somewhere?
One more thing ... where do I find what the maximum towing capacity is for a truck like this? I have the original manual (last guy left it in the truck), but it didn't seem to clearly list this.
Thanks for your help!
Ross.
Tow cap. should be on inside drivers door. Gears would be in glove box tag, GU5= 3.23, GU6= 3.42, GT4= 3.73 and GT5= 4.10's.
Discussion Starter #3
Thanks. That info is very helpful.
Does anyone know about whether it would be better to go down to stock tire size for towing?
Going to a smaller tire with act like you have steeper gears. I would try to see what gears are in the truck before I did anything. Most, but not all 4X4 'Burbs came with trailer towing packages that had the steeper gears.
Super Moderator
The trailer towing package I don't think neccisarily meant a steeper gear ratio. My R1500 suburban has the 10K towing package, but came with 3.08 gears. Speaking of 3.08 gears, its RPO code is GU4.
Could you explain this a bit more? I am kind of curious about swapping gears in my 99' K1500 5.7. What do the numbers mean in terms of power/performance etc? I see a lot of people have Yukon gears in their trucks, whats so special about those?
Super Moderator
The gear ratio describes how many rotations of the driveshaft are required to rotate the tires one full rotation. A lower gearing(higher numerical gear ratio) means you have higher torque at the wheel at the cost of top-end wheel speed assuming a constant input RPM. Conversely, a higher gearing(lower numerical gear ratio) means you have less torque at the wheel for a given input power/rpm, but the top-end speed is higher. What this means is that lower gearing is good for towing, and higher gearing is great for high speed and fuel economy. A common towing gear ratio is 4.10s, while vehicles geared for good fuel mileage might have something around a 3.08.
Yukon just happens to be a good quality aftermarket gear manufacturer, and virtually dominates the market. That's why you see people using Yukon gears a lot.
Another thing to be mindful of is that as you go with taller tires, you reduce your effective gear ratio.
1 - 7 of 7 Posts
